Orbi WiFi 7 RBE973
Reply
Please help me find my CAX80 power supply!
gil2009
For some reason I cannot find the model number of my power supply ! please help. I need to order a new one
Message 1 of 21
Guru
Re: Please help me find my CAX80 power supply!
netgear doesn't sell replacement power supplies.
You can usually pick up 3rd party supplies through ebay/amazon though.
I believe its a 19v 3.16amp power supply.
Message 2 of 21
gil2009
yes I already tried ordering one but the connector wouldn't fit.. I need a power supply without a pin inside the barrel
Message 3 of 21
Look for one that comes with a choice of barrels. Something like this:
Generic adapterGeneric adapter
Message 4 of 21
gil2009
to be honest I own a couple of these sets already and they don't come with this size. I must say the barrel size specs are quite unique.
Message 5 of 21
Guru
I would reach out to a forum moderator and ask them about the barrel connector. It is unique to the CAX80.
@olympos1625
Message 6 of 21
gil2009
I just need anybody who already owns this modem to tell me the model number... I'm sure I can find it on eBay..
Message 7 of 21
Guru
I see AD2003F10 listed on mine
Part Number is 332-11480-01
Message 8 of 21
The problem there is that if Netgear does not sell them, a model number may not get you very far.
But Amazon sellers sometimes list compatibility information for the generic devices on offer. eBay sellers may do the same thing.
Message 9 of 21
gil2009
@FURRYe38  Thank you very much! Unfortunately I was unable to find any on eBay at the moment. I will keep an eye out for one.. apparently it's really rare.
Message 10 of 21
olympos1625
NETGEAR Employee Retired
Hi @gil2009,
Welcome to NETGEAR Community!
We are sorry for not being able to get back to you immediately. May we know what happens to your CAX80 modem power adapter? Did you register the CAX80 to your MyNetgear account? If yes, please SM us the serial number of the CAX80 modem.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 11 of 21
Nima13
Hi gil2009:
were you able to find the adapter? I have the exact issue and it is really hard to find it. I will appreciate if you can help me. I had this modem/router for 13 months and even though I registered it, it is out of warranty now, and I have no idea where to find this power supply.
Thank you!
Message 12 of 21
Guru
Contact the forum moderator:
@olympos1625
@Nima13 wrote:
Hi gil2009:
Thank you!
Message 13 of 21
gil2009
. no luck. sorry. please let me know if you find something.
Message 14 of 21
AndyTomlin
I am having the same problem. I got a PSU off amazon an AD2003F10 but it has a pin in and doesnt fit even though it is 19V and 3.16A
Message 15 of 21
Guru
@olympos1625
@gil2009 @AndyTomlin
Message 16 of 21
Guru
When I looked on amazon for that same part number, I found a listing that looked perfect with a "genuine netgear" adapter. There was photos in the comments showing the original versus what they got. And its wrong. So not sure what they sent the user but it probably isn't correct. So you might just want to be a little careful when you order and compare the original with what you got.
Message 17 of 21
AndyTomlin
I contacted the moderator, but no reply
Message 18 of 21
AndyTomlin
@plemans The part I ordered was new and exactly what is shown in the picture, however the barrel on the connector is the small one with the pin. This is what I ordered, and it has the wrong connector:
https://www.amazon.com/dp/B084WMFLJS?psc=1&ref=ppx_yo2ov_dt_b_product_details
Message 19 of 21
Guru
It was that exact same post that had a user post that the one he got didn't match the original.
I have the CAX80 and its the larger diameter plug in the photo.
Message 20 of 21
AndyTomlin
This power supply works as a replacement: https://www.amazon.com/dp/B09XMFRLBG?psc=1&ref=ppx_yo2ov_dt_b_product_details
It has 2 styles of connectors included. It includes a connector for the socket without a center pin. Was able to power up my Modem, not tested everything out yet.
Message 21 of 21
Top Contributors
Discussion stats
  • 20 replies
  • 2320 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi WiFi 7
