cailubx11
Nov 06, 2017Aspirant
QOS Problem on Netgear cg3000dv2
now i dont know anything much about wifi configurations but it seems that my qos settings are disabled on my n450 (cg3000dv2) i have enabled my wifi multimedia and it says that i can configure my qos options there but theres no tab or links to edit my qos settings.
Are there any ways to enable it or anything to use it?
There is a manual for the cg3000dv2 somewhere at the end of this link:
>> Click here >> N450 | Product | Support | NETGEAR << Click here <<
Did you find the stuff on page 18? The manual says that it provides "basic Quality of Service (QoS) features". Maybe that's as far as it goes.
- cailubx11AspirantYes I have but are there ways to get it enabled.
- michaelkenwardGuru - Experienced UserAs I read it, make those settings and it will enable "basic" QoS for multimedia wifi.
