InRussia
Aug 11, 2019Follower
Router/Modem combo randomly restarts or drops connection when playing games/internet.
Title says it all, the restart usually takes a minute or so then works fine for maybe 4-5 hours but honestly its pretty random. Here are the event logs if someone can help, Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
You are getting a lot of T3 timeouts in your logs. This typically is an issue with the ISP you will want to have an ISP tech come out and check your lines in your home and in the neighborhood.
DarrenM
