Darnell's avatar
Darnell
Slow internet speeds CM500V wired
  • plemans's avatar
    What speeds do you pay for?
    What speeds do you get hardwired?
    Get a screen snip of the cable connections page and the logs and post them back here. that helps check the connection back to the isp.
    • Darnell's avatar
      Darnell
      I am using comcast internet service with internet speed of 200 mbps. I also use a tp-link AC1750 Wireless Dual Band Gigabit Router. My current internet speed at my computer ranges between 92 and 110 mbps on any given day. WiFi speed at modem ranges between 79 and 94 mbps. Before checking my speed, I always clear my browser and disconnect my vpn.
