MiRad
Jul 03, 2018Follower
Turn off WMM
Hello. I need to turn off my WMM because I see suttering when I use Airplay between my Mac and Apple TV. I have read that this may solve the problem. I tried to use the user manual for N450, but there is no WMM in the menu. Is there anyone who has solved this issue? Thanks.
1 Reply
> [...] I tried to use the user manual for N450, but there is no WMM in
> the menu. [...]
Which "the user manual"? Which "the menu"? Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual.
If there is no Setup > Wi-Fi Multimedia option (as described in the
User Manual), then firmware updates may have changed the options. Can
you find anything about "Quality of Service" or "QoS", instead of "WMM"?
A cable-TV ISP has complete control over the firmware of any
modem(+router) on its network. It's also possible that your ISP has
disabled such features.
> [...] I see suttering when I use Airplay between my Mac and Apple TV.
Do both these devices use wireless connections to the modem+router?
> [...] I have read [...]
I've read things, too, some of which were more useful than others.
