Nboudreau
Sep 12, 2017Follower
Unable to establish upstream connection
Hi there, I recently moved into a college dorm and purchased a CM500 modem and a nighthawk R7000 router in the hopes of having a wifi connection. When I went to establish a connection with the CM500 it continuously searched for an upstream connection, unable to find one. Every attempt to restart the modem and connect again was met with the same result. I was wondering if there was any way this problem could be avoided, or if my modem is faulty, or if there is a problem with the wiring in my building.
> connection. [...]
Have you tried asking the people who run the "a college dorm"? Does
that place really use cable TV connections for Internet access?
To me, that sounds as if you don't have cable-TV Internet.- michaelkenwardGuru - Experienced User
Nboudreau wrote:
Hi there, I recently moved into a college dormYou have bought a cable modem. Most college folks who turn up here say that they get the internet over an ethernet connection.
Can you just plug a laptop or PC into the college internet? If that works, then you may get by with just the R7000 router.
Why not ask fellow students what they use to get some local wifi?
