- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unknown Netgear IP address on network (CG3000V2)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently got a new cable modem from Optus (CG3000V2) and enjoy using Netgear Geni, but confused by an unknown device that keeps appearing at the same IP address (192.168.0.5). Recently checked Norton Network Map and find the same device. Have a sneaking suspicion it's related to the CG3000V2 itself (so close in MAC address isn't it!)
Since I'm not sure about posting full MAC addresses, I will remove the last 2 pairs.
The 1st device is the unknown
Unknown device 80:37:73:9E:xx:xx wired 192.168.0.5 ?seems always same IP (1st 6 indicate Netgear device)
Netgear CG3000v2 cable modem/rtr 80:37:73:9E:xx:xx no IP CM MAC (from dev label)
Netgear CG3000v2 cable modem/rtr 80:37:73:9E:xx:xx no IP MTA MAC (from dev label)
Netgear CG3000v2 cable modem/rtr 80:37:73:9E:xx:xx both 192.168.0.1 gateway
Look forward to hearing any suggestions as to how to identify this?
Is posting full MAC addresses here recommended? Will it help?
Thanks,
Larry
2015MY17 21:05 Sydney Australia
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unknown Netgear IP address on network (CG3000V2)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your quick reply
Sorry, was NOT suggesting the IP address indicated a Netgear device.
WAS suggesting the 1st 6 characters were the OUI and that they indicated it was Netgear device. Thanks for letting me know that this is not definitive.
However the MAC address is VERY close to that of the 2 on the CG3000V2 itself. And funnily enough the MAC address that appears on 192.168.0.1 Gateway IP address is NOT one of the two on the device label. But it IS as I said close to the unidentified device. (hence my providing the 4 albeit partially masked MAC addresses.)
That said, what CAN I do to simply determine what the device IS. Does the CG3000V2 use another IP address in any way?
One simple things didn't work to find out what the device is. Putting the IP address in a browser just came up as not available.
So do you have any simple techniques that could help me identify the device?
Thanks,
Larry
2015MY18 07:30 Sydney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, a few things I did since. Logged in direct to router on web interface (192.168.0.1) and the questioned IP 192.168.0.5 is NOT there. (using either basic or advanced menu items for map)
Netgear Genie and Norton Network Map both refresh to have the device on IP 192,168.0.5 and the MAC id (did you want the specific one? It's only the last 1 position (2 characters) different than the Netgear CG3000V2.)
Do you know how the CG300V2 acts / reacts? as in does it create a "ghost" device?
Thanks in advance,
Larry
2015MY18 11:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't need the MAC, there's no definitive way to determine the device from it, and not being a user of either Netgear Genie or Norton Network Map, I can't tell you how either one works - experience with Microsoft's LLDP (link layer discovery protocol) network mapping, which is what I suspect is being used by Genie & Norton, has shown me that the technology is perhaps not mature enough to be considered reliable - I have yet to see it show an accurate map (a quick check this morning shows one of my three switches and a printer missing, and a server showing up twice).
Many routers are also not reliable in their presentation of attached or connected devices - there are two methods generally used to gather the information, both with their quirks, and I have no idea which one the CG3000 uses.
If this sounds like I have little faith in these technologies, it's because I don't - I've investigated the quirks, I know why they don't work, I don't know of a guaranteed reliable way, and I just don't loose sleep over them.
If I want to know what is on my network (usually so I can find where it is, I will either use FING (which runs on an Android device) for a quick & easy check, or PacketTrap's network tools.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok using fing i got a response from telnet (port 23).
I used a telnet client on 192.168.0.5 port 23 and got a login prompt. Since I don't know the device I did a guest guest and admin no password and it failed. Since I am WAY out of my depth here I have no idea how to proceed. The telnet sw (vSSH Lite for the Mac) only gave me this display briefly but include it to see if it helps you decipher what the device is.
Here is a link to the screenshot - https://www.dropbox.com/s/zx11m7r6i97yfvc/Screenshot%202015-05-19%2010.26.43.png?dl=0
does that tell you anything about the device or does it only set up display parameters?
Thanks,
Larry
2015MY19 10:30 Sydney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Hjzamm,
The firmware on the CG3000v2 is provisioned by your ISP, please contact your ISP to configure your settings.
Please let me know if you need further assistance.
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey guys,
I can tell you that the 192.168.0.5 is actually the in built USB storage/NAS feature, and I believe it is also used in the in built media server functionality. I would love to know how to change that IP address as it is conflicting with my real NAS.
Any ideas on how to do that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had the same experience and have searched a few different forums. One answer i got was that 192.168.0.5 (with a very similar MAC as the 192.168.0.1) is the file sharing IP for the CG3000v2.
Cheers
Tony
