kala1331
Sep 10, 2018Follower
cm700 modem and google home
Hello all, I need some help been having an issue with the amount of devices on my home network, I have xfinity ~250mbp, I have 4 google mesh wifi routers and a cm700 netgear modem. I orginally had 3 routers hooked on and I noticed every time the 20th+ device hooked on the wifi that device will not connect to the internet, it connects to the wifi but then says there is no internt. If I unplug any device 1-19 and try the 20th device again it works and then if bring the other device I discunected it wont work and I try and add more devices 21-23 they all contect to my wifi but there will be no connection/internt. I got a 4th router thinking it was that but the same thing is happening so I think something is blocking more then 20 devices? is it the modem? its a CM700 32x8. Anyone else have this probelm? How do I fix it? i talked to comcast and they dont know and talked to google and they dont know so im thinking it a setting for the modem but im not sure where to start.
thanks for your time,
Ak
1 Reply
> [...] I have 4 google mesh wifi routers [...]
Do they have model numbers?
> [...] I think something is blocking more then 20 devices? is it the
> modem? [...]
The modem would be the least likely culprit, I'd say. It really
doesn't care how many devices are connected to your various routers.
