Retired_Member
Sep 27, 2017problems setting up remote ssh with netgear C3700-100NAS router
I've got an ubuntu desktop at home and a mac laptop. I'm trying to set this up so that I can ssh into my ubuntu machine from outside my local network.
Here is what I have done so far:
(1) I've enabled ssh on port 22 on my ubuntu machine. The file /etc/ssh/sshd_config says it is listening on Port 22.
(2) If I look at my firewall status (ufw status), it says:
Status: active To Action From -- ------ ---- 22 ALLOW Anywhere 22 (v6) ALLOW Anywhere (v6)
(3) On my Netgear C3700-100NAS router, I reserved the ip address to my ubuntu machine so that it won't change.
(4) I set up port forwarding, with service type TCP/UDP, with external port 8022 and internal port set to 22, and it points to my internal IP address.
(5) I found my public ip address using http://www.myipaddress.com/
I can successfully ssh into my ubuntu machine from home, on the local network, using the local ip address.
But remote ssh times out. I also tried an online port forwarding tester (https://www.yougetsignal.com/tools/open-ports/), and when I point it to my public ip address and port 8022, it tells me the port is closed.
When I attempt to remotely ssh, I get the following:
> ssh -vvv username@xx.xxx.xxx.xx -p 8022 OpenSSH_7.4p1, LibreSSL 2.5.0 debug1: Reading configuration data /etc/ssh/ssh_config debug2: resolving "xx.xxx.xxx.xx" port 8022 debug2: ssh_connect_direct: needpriv 0 debug1: Connecting to xx.xxx.xxx.xx [xx.xxx.xxx.xx] port 8022. debug1: connect to address xx.xxx.xxx.xx port 8022: Operation timed out ssh: connect to host xx.xxx.xxx.xx port 8022: Operation timed out
I can ping my public ip address.
Any ideas how to troubleshoot this?
1 Reply
Existence of a configuration file is not evidence of much.
> address.
This all sounds good, but copy+paste of the actual data/reports would
be more convincing than your claim that you did everything correctly.
That's better. From which system ("from home") into the "my ubuntu
machine"?
How "remote"? What happens if you do the same thing ("from home", on
your LAN) but specifying the public IP address and "-p 8022"?
> [...] port 8022: Operation timed out
If the server were entirely inaccessible, then I'd've expected
"Connection refused". (Try it to some odd-ball port, like, say, 8021,
instead of 8022.) I'd expect "Operation timed out" if the server didn't
have a valid route back to the client, or there's some firewall which is
causing replies to be discarded.
Nothing likely to be useful. I assume that Telnet to port 8022 would
suffer from the same sort of error as SSH. A C3700 is a cable router,
so I assume that there's no other router between "my ubuntu machine" and
the outside world.
You might see if you can rig port forwarding for some port
combination like ext=8089/int=80, and then see if a Web browser can find
the Web server on "my ubuntu machine" ("http://<public_ip_addr>:8089").
(You must be running one there, right?) The question would be whether
every port is blocked, or there's something special about 8022->22.
I do this stuff with my D7000 with no difficulty, but the SSH servers
here are on a Mac and a VMS system, not any GNU/Linux. Not that it
should matter, unless there's a rogue firewall somewhere in your stuff.
