× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 – Nighthawk LTE Mobile Double Nat on Xbox
Speedsk8
Tutor
Trying to grt rid of Double NAT on son's Xbox Have a Nighthawk LTE AT&T Modem thta directly feeds a unmanged switch. I have set the XBox to a static IP outside my DHCP pool, Set up the port forwarding in the router/modem for all of XBoxes listed ports including the alternate. I have tryed both wired and wireless conections. Still get the double NAT. Getting anoyed as I am ussally the one fixing IT issues for others.
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: MR1100 – Nighthawk LTE Mobile Double Nat on Xbox
> MR1100 [...]
   Firmware version?
> [...] the router/modem [...]
   That's the MR1100, not some additional device?
   What's the WAN/Internet IP address of the MR1100?  Is it a public or
private address?
   If your ISP uses carrier-grade NAT, then that would put an additional
NAT router between the Internet and your router.
      https://en.wikipedia.org/wiki/Carrier-grade_NAT
   Note that there's a forum for these devices:
      https://community.netgear.com/t5/x/bd-p/aircard
Message 2 of 4
All Replies
antinode
Guru
> MR1100 [...]
   Firmware version?
private address?
Message 2 of 4
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
Message 3 of 4
Speedsk8
Tutor
Apparently it is at the Carier Nat. I suspected it to be at AT&T's level. Hopefully our local power comany will have fiber to our area in the next year and I can say bye to my AT&T.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5194 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
