× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear Nighthawk M2 - MR2100 - Wifi has red circle X and battery not charging
francsitdayalo
Follower
Hi, I recently got the Netgear Nighthawk M2 and I havent used it in a month, when i tried opening it it doesnt emit a wifi signal and the wifi icon has a red x on it. i tried turning ssid on and off and wifi still wont work
Second Problem:
I tried charging it for a trip and the  unit would just heat up and not charge,
i hope somebody could help me with this problem for i dont want to waste any money buying an expensive product like this
@Blanca_O  @Dustin_V
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 3
JohnPeng
NETGEAR Expert
Re: Netgear Nighthawk M2 - MR2100 - Wifi has red circle X and battery not charging
Can you do a factory reset to see whether the issue goes away? Did you buy it brand new?
Thanks
Message 2 of 3
kazuar
I have exactly the same problem. I got a brand new device and the wifi is not working from the beginning. Cable connection works fine. Any idea? Seems like this device is faulty.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1601 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
