davidgriffo's avatar
davidgriffo
NightHawk M2 is not showing data usage.
I have a new M2 and this is often displayed in all the advertisements showing the data used and the amount left on your account.
This is a great feature but will not work on my new m2.
Is there a setting  on the M2 , that I need to change to display the data usage, or is this purely a function of my service provider?
  • michaelkenward's avatar
    michaelkenward
    Did you try this?
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check the section View Your Data Usage.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi davidgriffo,
      May we please know the device SKU (e.g. MR2100-1TLAUS)? This can be checked on the box of the product or on the barcode label
      What is the Firmware version?
      Who is your Internet Service Provider?
      Blanca
      Community Team
      • davidgriffo's avatar
        davidgriffo
        Hi
        The SKU :
        MR2100-1TLAUS_04.02.181.00
        FIRMWARE VERSION:
        NTGX24_10.19.03.00
        INTERNET PROVIDER:
        Telstra
