Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M6 5G WiFi 6 Mobile Router Turn Specific Channels On/Off
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-24
12:07 PM
2023-03-24
12:07 PM
Is it possible to turn specific channels off across the 5G band on this device? Or am I limited to turning the 5G or 2.4G on or off as a whole?
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-25
06:33 AM
2023-03-25
06:33 AM
Re: Nighthawk M6 5G WiFi 6 Mobile Router Turn Specific Channels On/Off
If you use the netgear mobile app you can go in through wifi settings and change the channels.
Just tested it to ensure on my MR6110
NETGEAR Mobile App | NETGEAR Support
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-25
10:19 AM
2023-03-25
10:19 AM
Yes. You can manually set which WiFi channel to use on 5G or 2.4G. But you can only set the device to use one certain channel.
Thanks
John
Message 3 of 3
Announcements
