× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Port Forwarding Not working
kevinpaynter
Follower
I have recently purchased a Nighthawk M1 and this replaces my existing netgear router. The software with router has a port forwding area which I have openned however whenI check it is telling me the service is unavailable
 have no idea what I am meant to do, as Its open with old router if I swap it out but not new one.
Message 1 of 4
Blanca_O
NETGEAR Moderator
Re: Port Forwarding Not working
Hi kevinpaynter,
Welcome to NETGEAR Community!
- May we please know the exact model of your MR1100?
- What is the firmware version?
- Who is your Internet provider?
Blanca
Community Team
Message 2 of 4
schumaku
Guru
Looks like a Testra IP address.
Using the same SIM and contract as before?
Does your M1 have a public IP address assigned by the mobile ISP? If there was a contract change, you might have to request this again.
Message 3 of 4
ArodiD
NETGEAR Expert
Hi @kevinpaynter ,
The IP address that is showing in your screenshot looks to be a NAT'd IP from memory which will block ports from the network side.
Can you check the APN settings on your old router to see if it matches with the MR1100.  I suspect your old router APN profile might be telstra.extranet and the APN profile used on your new router is telstra.internet.  If so, then create a new APN profile with telstra.extranet on the MR1100 and set it to be the default profile and it should start working for you.
Arodi
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2547 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
