epsom11's avatar
epsom11
Tutor
Apr 12, 2020
Adobe Lightroom not able to verify subscription if desktop added to Circle
Hi - has anyone seen this issue...
If I add my desktop as part of "home' or another profile (like myself), make the Filter 'Adult' - I note that Adobe Lightroom (both Classic and CC) are unable to validate their subscription and as a result will not run. If I make this desktop 'unmanaged', it's good again.
Any ideas please?
Thanks
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi epsom11,
    Are you provided a URL that Adobe Lightroom uses to verify subscription? If so, you may need to set the URL to "Allowed" in the customer filter. You may also check your history (located in the profile) and select it as unmanaged.
    Christian
