Orbi WiFi 7 RBE973
Reply
Circle down
rich_benson
Circle down
Been using Parental Controls (on Netgear) for years, and had trouble with stable network connections (and certificate issues (Circles technique for controlling traffic) the last few days. After disabling Parental Controls (to restore internet connectivity), the option to re-enable the feature is greyed out?
NighthawkNighthawk X6 R8000
Firmware Version
V1.0.4.84_10.1.84
and
NighthawkNighthawk X6 R7850  (AP Mode to above router)
Firmware Version
V1.0.5.84_10.1.84
Been using Parental Controls for years, and had trouble with stable network connections the last few days. After disabling Parental Controls (to restore internet connectivity), the option to re-enable the feature is greyed out???
I have the premium Circle App so a refund may be in order if they are discontinuing services.
Netgear team response feedback needed - as I have read articles about Circle going away as a feature offering?
Message 1 of 4
Accepted Solutions
Guru
Re: Circle down
The mobile app is the only way to control Armor or SPC now days.
Message 4 of 4
All Replies
Guru
Re: Circle down
Probably Circle is going away. Have you tright the Nighthawk moble app to see if SPC is available there?
Message 2 of 4
rich_benson
Re: Circle down
I remove the nighthawk mobile app sometime ago. I will give that a try.
Message 3 of 4
Guru
Re: Circle down
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2156 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
