SilverWinterSky's avatar
Mar 27, 2021
Circle002 certificate issue
My sons Macbook is suddenly unuseable on our Orbi wireless network, showing the dreaded “This connection is not private” error on all browsers.
The associated certificate is Circle002.
I’ve tried disabling Circle. I’ve tried deleting the certificate. No progress.
If anyone can offer any help on this I’d be so grateful. Thank you in advance.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello SilverWinterSky,
    May you forget the WiFi network on your son's Macbook and reconnect to the network.
    Christian
    • SilverWinterSky's avatar
      SilverWinterSky
      Thank you. I will try what you suggest.
      Can you explain why it might help?
        Christian_R
        This is to help isolate the root cause of the issue you're experiencing since the Macbook seems to be the only device you're having issues with.
        Christian
