Orbi WiFi 7 RBE973
Reply
HOWTO enable Adblock on Circle?
9re990
I have an R6400v2 (Nighthawk AC1750)
Firmware V1.0.4.82_10.0.57
Circle Parental Control Info
Agent Version: 2.0.8.9
App Database Version: 1.3.1
How do I enable the adblock feature? Is ad blocking part of any Filter Level?
I have configured myself as a user in Cirlce and my laptop and phone do appear in my device list. I have tried all filter levels, but am still seeing ads on my devices.
What I can do is go to a site e.g. washingtonpost.com and then check my visited history on the circle app and manually block all domains that seem look like analytics or ad services corresponding with the time I loaded the webpage. For the above site, I get:
app-measurement.com
apptentive.com
bizbible.com
cloudflare.com
cookiebot.com
crazyegg.ecom
g2crowd.com
lookbookhq.com
marketo.com
mktoresp.om
and more.
I can manually block all the URLs until site breaks and then maually un-block sites untl the site loads, but this can't be what Circle had in mind when they say ad blocking is a feature.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: HOWTO enable Adblock on Circle?
Hi @9re990, engineering has confirmed that the ad blocking feature has been discontinued. When using a desktop browser, you can install ad blocking extensions instead.
Dexter
Message 3 of 5
All Replies
DexterJB
NETGEAR Moderator
Hi @9re990, welcome to the community! Let me check on this and get back to you.
Dexter
Message 2 of 5
DexterJB
NETGEAR Moderator
Dexter
Message 3 of 5
9re990
Okay. Thanks looking into this and responding.
Hopefully they will stop listing adblock as a feature in their service, as continuing to promote it would be misleading.
Message 4 of 5
DexterJB
NETGEAR Moderator
Hi @9re990, yes, this has been reported to the appropriate team to have it corrected. Thanks!
Dexter
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4635 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
