Orbi WiFi 7 RBE973
Reply
Nighthawk X6 R7900 - How to schedule blocking internet for kids computers.
bLampert
Just bought this router the other day. My previous Asus router had the ability to turn off internet access per device on a set schedule. I was able to turn off the internet for my kids computers everyday @ 10PM and turn back on at 7AM. Is this possible for this model router? Otherwise i'll have to return it.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 6
microchip8
Master
Re: Nighthawk X6 R7900 - How to schedule blocking internet for kids computers.
Go to Advanced -> Security -> Block Services and use port 1 - 65535 for the IP you need to block
In Advanced -> Security -> Schedule you can set when to block
Message 2 of 6
bLampert
Which port number do I need to input?
Message 3 of 6
microchip8
Master
if you want to really block everything, then all ports from 1 to 65535
Message 4 of 6
bLampert
Ok I think i have it figured out but it seems like I can only set only one schedule for devices. Is there a way to set more than one schedule? Like I usually had the kids PC's internet shut off at 10PM Monday-Thursday, then for them to shut off at 12AM Friday & Saturday.
Message 5 of 6
Also investigate Parental Controls.
There is a manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
See page 54.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3158 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
