Reply
Prodigy
CouchPotato 0.40
CouchPotato 0.40
  • Description:
    CouchPotato (CP) is an automatic NZB and torrent downloader. You can keep a "movies I want"-list and it will search for NZBs/torrents of these movies every X hours. Once a movie is found, it will send it to SABnzbd or download the torrent to a specified directory.
  • Requirements: RAIDiator 4.1.6 or newer (may work with earlier versions but that's untested)
    For this add-on to work,the Python2.6 add-on has to be installed on your ReadyNAS.
  • Platform: Sparc
  • Current Version: CouchPotato 0.40 v0.1.4
  • Features:
    • Can be upgraded right on the ReadyNAS
    • Automatic downloading and sending of NZBs to SABnzbd
    • Automatic downloading of torrents files to a specified directory
    • Easily add movies via IMDB UserScript
    • Movie sorting & renaming
    • Trailer downloading
    • Quality options to download best available. Overwrite if better is found.
    • A "Coming Soon" page with soon to be released DVD and Theater info.
    • Support for NZBs.org, NZBMatrix, Newznab.com and ThePirateBay.
  • Changes in this release:
    - Fixes a problem where the SABnzbd integration could accidentally remove the API key for "TheMovieDB" from CouchPotato's config, thus making movie lookups from that souce impossible
  • Details/Installation:
    • After installation of the add-on, CouchPotato's web interface can be accessed by typing http://<ip of your NAS>:5000/ in your browser's address field.As an alternative you can use the quick link from the add-on's section in the "Services" -> "Installed Add-ons" tab within Frontview. You will be presented with a login screen.
    • The default username is admin with a default password of netgear1.
    • After logging in with these credentials please configure HeadPhones to your needs - don't forget to change your password Smiley Wink
Follow me on Twitter, Facebook, Google+ or visit my add-on web site
Prodigy
Re: CouchPotato 0.40
Updated to: CouchPotato 0.40 v0.1.4
- Fixes a problem where the SABnzbd integration could accidentally remove the API key for "TheMovieDB" from CouchPotato's config, thus making movie lookups from that souce impossible.
Discussion Stats
  • 1 reply
  • 2887 views
  • 0 kudos
  • 1 in conversation
