super_poussin's avatar
Apr 25, 2009
DnsOmatic
DNSoMaTIC
  • Description:
    • For Users
      DNS-O-Matic provides you a free and easy way to announce your dynamic IP changes to multiple services with a single update. Using DNS-O-Matic allows you to pick and choose what Dynamic DNS services you want to notify, all from one easy to use interface.
    • For Developers
      DNS-O-Matic provides a scalable and standardized solution for developers to easily provide support for all dynamic DNS / IP services in their software or platform with one simple and consistent API at no cost.
    • For Dynamic DNS Providers
      DNS-O-Matic will support dynamic DNS services without any work on your side. As more software clients and hardware vendors adopt the DNS-O-Matic API, the reach and ease of adoption for your service expands automatically.
  • Supported Dynamic Dns Providers:
  • Requirements: RAIDiator 4.1.4+
  • Platform: Duo/NV+/1100
  • Current Version: 2.0
    DnsOMatic
    This add-on will update the accounts you specify in your DnsOMatic profile
    Thank you to Sergio for pointing the problem in 1.4
    if @IP did not change after one month, the add-on will force a dnsomatic update
    revert back to fixed path for curl :)
    Solve a problem for non english language NAS
    better password support in case of special caracters like - $ ...
    • Installation Notes:
      • Please follow the steps :
        • you need to open an account on http://www.dnsomatic.com
        • setup te different accounts you want
        • instal the add-on
        • edit /c/addons-scripts/DnsOMatic/dnsomatic and put your username/password in it
        • wait 5 minutes
        • to see /addons-scripts a reboot is required
        • ScreenShot:
      • Credits:
        Official DnsOMatic Web site
ProSupport for Business
