btaroli
Feb 17, 2012Prodigy
(RESOLVED) dnsomatic issue
Hrm... seems that the company has disabled http://myip.dnsomatic.com and refers it back to top page of http://www.opendns.com. In looking through their dev documentation, it seems you can get similar output from checkip.dyndns.com, but it requires a bit more sifting because it comes wrapped as standard HTML output. So you can't just modify the URL in /c/addons-scripts/DnsOMatic/dnsomatic.
To resolve the issue, I changed this line of the dnsomatic script
to
Also be careful about your update frequency... they seem to now suggest no more often than 10 minutes.
IP=$(/usr/local/bin/curl -s http://myip.dnsomatic.com/)
to
IP=$(curl -s http://checkip.dyndns.com/ | sed 's/.*:[ ]\(.*\)[<]\/body.*/\1/')
- etonLuminaryThanks btaroli
I've got e-mail-bombed by DNS-O-Matic for abuse. Strange, because I have used the same settings for a long time and had got no prolems with that. Maybe they changed their allowed update frequency.
Does DNS-o-Matic not have a skip variable like the DynDNS client?
Example of Dyndns Client - settingsuse=web, web=checkip.dyndns.com/, web-skip='IP Address'
I have collected some "my ip" services:http://myip.dnsomatic.com
http://ip1.dynupdate.no-ip.com
http://checkip.dyndns.com - JarnoGGuideThanks! I've had the abuse mails as well, but couldn't find what the problem is and just turned the add-on off.
I didn't check it before, but if I check http://myip.dnsomatic.com, then it just returns my IP like it used to do... Maybe it was a problem they had at dnsomatic and which is fixed now? - btaroliProdigyI just re-checked after flushing DNS cache and the http://myip.dnsomatic.com/ address seems to be working again.
- etonLuminaryDue to all problems I switched to: D(yn)D(ns)Client 3.8.1 (Sparc)
viewtopic.php?f=47&t=62337
