btaroli
Feb 17, 2012Prodigy
(RESOLVED) dnsomatic issue
Hrm... seems that the company has disabled http://myip.dnsomatic.com and refers it back to top page of http://www.opendns.com. In looking through their dev documentation, it seems you can get similar ...
JarnoG
Feb 20, 2012Guide
Thanks! I've had the abuse mails as well, but couldn't find what the problem is and just turned the add-on off.
I didn't check it before, but if I check http://myip.dnsomatic.com, then it just returns my IP like it used to do... Maybe it was a problem they had at dnsomatic and which is fixed now?
