× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NasMonitor
super_poussin
Virtuoso
NasMonitor
NAS MONITOR
    • Description: Nas Monitor is a "triple plugin" by default it will launch loadavg which display MeMory and ethernet interface usage
      loadavg is a simple and lightweight method of monitoring load, memory usage and transfer throughput on a Linux server. Every method of monitoring has an impact on the system being monitored -- loadavg is designed to keep that impact as low as possible. It generates HTML & CSS charts, thereby shifting much of the work from the server to the client -- your web browser.
      phpSysInfo is a PHP script that displays information about the host being accessed.
      It will displays things like Uptime, CPU, Memory,
      vpsinfo is a Linux server monitoring script, written in PHP, that provides web access to system status information. It gathers the output from several common Linux commands into one web page, providing a quick overview of the system's current state.
    • Requirements: RAIDiator 4.2.15+ and PHP ADD-ON
  • Platform: PRO/NVX
    • Current Version:3.6.11
      NAS MONITOR 3.6.11
      NAS MONITOR 3.6.00 (03/25/11)
      NAS MONITOR (08/28/10)
        • correct uninstall script
        • Loadavg updates
        • PHPsysInfo upgraded
        • better upgrade procedure
        • correct a bug which make addons not stay enabled after reboot
        • whois and uniq support added
        • NAsMonitor can be disabled from frontview
        • New NasMonitor version (Whois supported ...)
        • Support of Disk spindown added
        • Button for each software added in the ui
        • PHP removed from addons to reduce size need to install PHP add-on if the addon was never installed
      • Crontable corrected
  • Screenshots:
  • Old Versions: removed.
Message 1 of 7
super_poussin
Virtuoso
Re: [PRO] NasMonitor
updated
Message 2 of 7
super_poussin
Virtuoso
Re: NasMonitor
updated
Message 3 of 7
super_poussin
Virtuoso
Re: NasMonitor
updated
Message 4 of 7
super_poussin
Virtuoso
Re: NasMonitor
updated
Message 5 of 7
super_poussin
Virtuoso
Re: NasMonitor
updated
Message 6 of 7
super_poussin
Virtuoso
Re: NasMonitor
updated
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 7332 views
  • 0 kudos
  • 1 in conversation
Announcements
