dsm1212
Oct 06, 2011Apprentice
NASMonitor: Loadavg problem
Installed NASMonitor along with WhoCares? version of PHP5. I'm using https with Frontview. The launch icons on the addon page don't work. I just get an about:blank window for each. I'm thinking this is because of https? If I manually launch loadavg, I get a loadavg login window. I login but it just redisplays the login window. NASinfo and PHPsysinfo work when I enter their URLs. I can't find anywhere what the right URL is for vnstat. I tried using both NASmon/vnstat and NASmon/vnstat.php but neither worked. Another topic here suggested deleting the "check for updates" section of the security.php file and I did that, but no change.
steve
steve
- dsm1212ApprenticeNot sure what happened, but I emptied /c/webroot/loadavg/config.xml.php since it looked that would trigger a reinstall. It did and then it worked. Maybe I had a typo or something in my password.
- dsm1212ApprenticeCouple of problems related to https I might as well report here. There is a force https checkbox in the settings and this works for the main loadavg page, but then the tabs for "server" and "settings" don't work. The problem is those two php scripts don't "require" settings.php for some reason. Adding that require caused other problems so I just added the line "settings['secure_conn']='on';" to both files before the security.php file and it caused them to work for me using https.
thanks,
steve
