Bamanamanana
Jun 15, 2024Follower
GS110MX Update/Refresh?
Have been using for some time, excellent product, but as more and more devices support 2.5G am looking for a similar product that will support them (the two 10G ports are in use).
Ideally a GS110MX with an update/refresh on the 1G side, to 2.5G...
...anything in the pipeline?
Best I can find that's reasonable is a QNAP 4*2.5G + 2*10G, would love an 8*2.5G version.
MS108UP or the more competitively priced MS108EUP Plus model, or the smart managed MS108TUP including full Insight management? Yes, a 4x60W plus 4x30W PoE with total 230W available don't come for free. Next up MS510TXUP ...
- BrianLNETGEAR Moderator
Hi Bamanamanana,
Welcome to the Community!
For your needs, I will take a look at the model numbers mentioned by schumaku.
Kind regards,
BrianL
- QuintLeoAspirant
I would also like to see a variation on the GS110MX with the 1GB ports replaced by 2.5GB ports.
In fact, that's SPECIFICALLY why I came to NetGear's site today, was to inquire as to if they were working on such a product.
- ErwinLNETGEAR Moderator
Hello QuintLeo
We have 8 port and 5 port switches with 2.5G that you can check below:
8 port with 2.5G
MS308
MS308E
MS108EUP
MS108UP
MS108TUP
5 port with 2.5G
MS305
MS305E
MS105https://www.netgear.com/business/wired/switches/plus/
https://www.netgear.com/business/wired/switches/unmanaged/
https://www.netgear.com/business/wired/switches/smart-cloud/Have a lovely day,
Erwin
Netgear Team
