Brad949's avatar
Brad949
Air Print problem following wifi router reset
I have 2 HP printers on a home network via ethernet cables. I have 2 R6400 wifi routers for wireless connections.  Our apple mobile devices have been able to print to these network printers using air print ever since I installed the routers (3+ years), but when I recently reset the wifi routers, due to some internet connectivity issues, they no longer see the 2 network printers and "no air printers found" is the result. I've tried resetting the network and deleting and reinstalling the printers.  I've looked for settings on both the printer and router apps involving air print, but can't find any. AllI I can assume is that something got triggered by the router reset, but I can't find out how to resolve it.
  • plemans's avatar
    If you're running 2 routers, you put the 2nd one in access point mode to prevent a double nat, didn't you?
    Otherwise you have 2 networks running. Maybe the printers are on one and the devices on a different one.
    • Brad949's avatar
      Brad949
      Thanks for the reply.
      The setup instructions did not advise on how to handle a second router,so I just set them both up with the same ID and everything worked fine for 3 years, until I had to reset them recently.  When I look at the devices recognized by each router, via the nighthawk app, the printers don't register on either.  This is because, with an Ethernet cable attached, they don't transmit a wireless signal.  But, somehow, AirPrint was able to use the wifi to communicate with those printers on the network, but not after the router reset.  I've tried to update the router firmware, which I suspect is the problem, but it fails through the nighthawk app and the netgear site says that free support for for these routers expired.  So, do I spend $$$ with netgear to try to resolve the problem on routers that are nearly 5 years old, or spend $200 for comparable new ones?  Unless I find an easy fix that's free, i
      l probably just go new.  Thanks again for trying to help.
      • plemans's avatar
        If your printing over airprint with a direct connection device----printer, then the router has nothing to do with it.
        If you're print airprint with the printer hardwired into the router, then you do need to have your network setup right.
        Did you put the 2nd router in access point mode? You didn't address this
