Gdog1's avatar
Gdog1
Follower
Nov 30, 2021
Can I use more than one EX6120 with my network?
I have an R6400 router with one EX6120 extender. It works well, but I could use another extender. Can I use two EX6120s without causing a problem?
  • michaelkenward's avatar
    michaelkenward
    No reason why it shouldn't work. But you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • plemans's avatar
    I don't generally recommend more than 1 extender.
    when users are needing more than 1 extender, I usually recommend moving to an actual mesh system designed for multiple nodes.
    With that out of the way, You can use more than 1 extender.
    I'd highly advise you against daisy chaining them. I'd set them up in a star configuration.
    Star: Extender<--------router-------->extender
    Daisy: Router------->extender------->extender
    Reason why is the extenders have to use the same chip to go route---->extender and then extender---->devices. And they can't do both at once. so their thoroughput is cut in half.  If you're daisy chained and add another extender on the end and its cut in half again. so the 2nd extender at best would only get 25% of the original speed. And thats without taking into account interference, obstructions, distance, etc. With those included, your speeds are significantly lower.  Plus it increases latency.
    so overall, can you do it? Sure.
    Should you do it? Depends on your situation.
