× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't find my network?
alisha2602
Follower
Internet is working fine on desktop computer, but can't access the wifi. When I search for my network on a wireless device, the network doesn't even show up anymore. It was working fine yesterday. I've already tried to unplug and reset everything. On the desktop netgear genie it is saying under WiFi connection that the status is not enabled
Please help! Been searching and trying stuff for hours now 😞
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Can't find my network?
Hi @alisha2602,
1. Are the 2.4GHz and 5GHz LED's lit? If not, try pressing the WiFi on/off button on the front panel as described on page 10 and 11 on the user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_11jun32015.pdf
2. The wired desktop computer may not be WiFi capable and that's the reason the Genie indicates that it is not enabled.
3. Please try using other wireless devices (smartphones, tablets, laptops).
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @alisha2602,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @alisha2602,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 11981 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
