slsnyder348's avatar
slsnyder348
Commercial Electric plug won't connect
N300 wireless router WNR2000v3
  • plemans's avatar
    More info would be beneficial.
    WNR2000 is your router?
    What modem/gateway are you using?
    What actual issue are you having? Whats it doing?
    • slsnyder348's avatar
      slsnyder348
      Modem is Netgear ADSL2 + modem DM111PSPv2
      When the app SP1 tries to connect to my Netgear it says connection failed, try again. I have reinstalled app, reset internet and smart plug, turned phone off, etc. I know the app and plug work because it connected right up at my daughter's house. Also have a Google mini which works just fine.
      • plemans's avatar
        This wasn't much clearer than the rest.
        Your trying to connect a smart/plug switch and it doesn't connect?
        you have a DM111PSPv2 connected to the wn2000? is that correct?
        but having issues with a smart plug
