× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Guest network isolation with WAC104 access point
This is a question about the 'guest network' feature on my DGND3700v1 router (with richud firmware and Genie interface) when there is also a WAC04 access point on the network. The router supports 'Guest networks' with settings like 'disallow guest from my local network'. I like the idea of this, because I have several PCs on my home network using cable and non-guest wi-fi.  So I'm planning to have a 5GHz Guest network with just my wired/wireless printer on it, so visitors can only print and see the internet. Now, here's the thing:
I also want to connect (by cable) a Netgear WAC104 access point to the router, to extend wi-fi coverage to my attic office, plus have it provide a few wired connections for my PCs up there.
I plan to set the WAC104 up to broadcast the same SSID/password/encryption as my intended Guest network on the DGND3700 so that visitors only need one login throughout the house BUT looking at the setup screens in the WAC104 user guide online, it seems to have no concept of 'guest network' as such. Its wireless setup form lacks those 'disallow guest from my local network' type options.
So the question is, if a visitor connects as guest at the WAC104 (rather than at the DGND3700) would they therefore have a route to my PCs, or would they encounter the blocks imposed by the guest network settings on the DGND3700?
Model: WAC104|Dual Band 802.11ac
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: Guest network isolation with WAC104 access point
> [...] looking at the setup screens in the WAC104 user guide online, it
> seems to have no concept of 'guest network' as such. [...]
   I know nothing about the WAC104, but I'd expect that.
   The guest-network implementation on Netgear routers seems to be a set
of firewall-like (router) rules which affect the "guest" wireless
clients.  A wireless access point which is separate from the router has
no way of employing any such router-based rules.
> [...] if a visitor connects as guest at the WAC104 (rather than at the
> DGND3700) [...]
   The whole guest-network concept is confined to the DGND3700 (router);
there is no "as guest at the WAC104".
> [...] would they therefore have a route to my PCs, or would they
> DGND3700?
   When any device is connected to the WAC104, the DGND3700 will see it
as a wired client device (hence not a "guest"); just another device on
the (extended) LAN.
   There may be ways to employ multiple (consumer-grade) routers to
provide a "guest" LAN subnet and a non-guest LAN subnet, with the
desired type of isolation between them.  Or, a more sophisicated router
with Virtual-LAN (VLAN) capability (about which I know nothing) could
probably do the job.  But I don't see a way for a DGND3700 and a WAP to
do it.
Message 2 of 4
All Replies
antinode
Guru
> DGND3700) [...]
> DGND3700?
the (extended) LAN.
do it.
Message 2 of 4
That doesn't yound hopeful. Although where you say 'no concept of guest at the WAC104, I suppose rather than 'connect as guest', perhaps I should have said for clarity 'connect to the wi-fi network at the WAC104 which is defined as guest at the DGND3700', but it looks like it makes no difference.
Perhaps I'll take up my ISPs offer of a free router and move my DGND3700 upstairs....
Message 3 of 4
antinode
Guru
> [...] perhaps I should have said for clarity 'connect to the wi-fi
> network at the WAC104 which is defined as guest at the DGND3700', [...]
   How, exactly, is "the wi-fi network at the WAC104" "defined as guest
at the DGND3700"?  Guest-ness is a property of a device which is
wirelessly connected to the router which established the "guest
network".  Nothing to do with the WAC104.
> the (extended) LAN.
   Still true.
   The price seems right for some experimentation.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3859 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
