jlynn2303's avatar
jlynn2303
Follower
Dec 28, 2020
NETGEAR AC1750 MODEL R6400 JUST STOPPED WORKING
Hi,
Everything was working just fine. I was gone from home for almost a year, so I had my internet service shut off, but did not disconnect any of the equipment. When I returned home and activated my internet service, it shows that the modem is working, but the wifi router is not. If I plug an ethernet cable into the router and my laptop, it shows my network with the old name etc.  and I have internet access. If I unplug it, I do not see my network. The first two lights are white on the router, and then one other is also white, depending on which port I plug the ethernet cable that I run to my laptop into. I have tried resetting the modem, resetting the router, turning everything, including the computer on and off again, without success. When I search for wifi networks using my phone, I do not see it either. I am puzzled, as no one has used it since I left, and I do not know why it would suddenly stop broadcasting. I can see the network name only when I use an ethernet cable to plug it into my laptop from the router. When I was trouble shooting it with xfinity, they show the connection as good at their end.
Suggestions?
Thanks,
Jennifer
1 Reply
  • > Model: R6400|AC1750 Smart WiFi Router
       Is that accurate?  R6400[v1] or R6400v2?  Look for "Model" on the
    product label.  Firmware version?
    > [...] If I plug an ethernet cable into the router and my laptop, it
       So, the router and its ISP connection are working, but not the
    wireless part?
    > [...] The first two lights are white on the router, [...]
       Instead of making everyone else fetch the User Manual for your
    router, and count the LEDs, how about if _you_ fetch the User Manual,
    and use the _names_ of the LEDs?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for the LED descriptions and "Troubleshoot".  Pay particular
    attention to the "WiFi On/Off button with LED".  Did you press it?
    Further reading might not hurt, either.
