Reply
OpenVPN with iOS
Retired_Member
Not applicable
OpenVPN with iOS
Brief history: I upgraded to Cox Gigablast and they included a Netgear R6300v2.  I had a VPN on my previous router (ASUS Dark Knight) that I used for conneting securely in places that aren't secure.  Coffee shops, airports, etc.
Trying to setup the is OpenVPN vpn on the router and I have it all setup with a DynamicDNS service and everything.  Downloaded Certs and OVPN file and imported into iPhone.  Open up the OpenVPN app and import in the profile.  It gives the following error: "iOS doesn't support TAP-based tunnels"
In doing research, apparently I have to setup a TUN based vpn so that it will work with IOS.  Is there a way for me to switch this vpn tunnel to a TUN based type?  I can't seem to find a setting for that.  Any help would be greatly appreciated.  Thank you!
Message 1 of 6
Accepted Solutions
storm1985
Prodigy
Re: OpenVPN with iOS
It doesnt support OpenVPN for iOS or Android. You should see the highlighted options below if R6300v2 does support Smartphones.
Message 6 of 6
All Replies
storm1985
Prodigy
Are you using a NETGEAR firmware? I dont think R6300v2 has openVPN feature.
Message 2 of 6
Retired_Member
Not applicable
It does.  Under advanced tab, advanced setup.  You have to setup a DynamicDNS obviously and then turn on the VPN option.  Screen Shot 2015-10-14 at 1.27.56 PM.png
Message 3 of 6
storm1985
Prodigy
FW 1.0.3.30?
Message 4 of 6
Retired_Member
Not applicable
Sorry forgot to include that.  Yes I'm at V1.0.3.30_10.0.73
Message 5 of 6
storm1985
Prodigy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 14448 views
  • 0 kudos
  • 2 in conversation
Announcements
