- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Opening ports and public ip
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to network to my defender security system . Need to open ports 80,5000,9000,18004
Told ip is private needs be public
Please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Opening ports and public ip
> Have a orbi 6 rbk753 ax4200
Connected to what?
> [...] Need to open ports 80,5000,9000,18004 [...]
Says who? For outgoing connections (no action needed), or for
incoming connections (unlikely, port forwarding might be needed).
> [...] Told ip is private needs be public
With my weak psychic powers, I can't see it from here. Point a web
browser at the management web site of your router, and report what you
find at: ADVANCED > ADVANCED Home : Internet Port : Internet IP Address.
Plug that address into the form at: https://whois.arin.net/ , and see if
it is a public or private address.
The usual cause for that to be a private address would be connecting
the RBK753 router to some other router -- either a device on your
premises, or one at your (unspecified) ISP, if they use carrier-grade
NAT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
rbk is conected to a spectrum modem
I can view my camers home with a app on my phone (defender clear vu ) wifi but not away .
working with net gear tech we were able to open the ports needed told me possibly the ip adress 172. is private and not public a class B .
thanks any thoughts
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the details. So, if I plug "a spectrum modem" into my
search engine, I'll get all the information about _your_ modem?
> [...] told me possibly the ip adress 172. is private and not public a
> class B .
From "172.", I can't tell.
You can see that address, and I can't. Which of us, do you think,
should try that experiment?
> [...] or one at your (unspecified) ISP, if they use carrier-grade NAT.
> https://en.wikipedia.org/wiki/Carrier-grade_NAT
Ask your ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
They told me the 172. Ip is one created by my net gear router it not there’s
Can the ip be changed in my router ?
Thanks all
- Mark as New
- Bookmark
- Subscribe
- Permalink
> there's
Ok. And if I could see what it actually is, then perhaps I could
tell you something, too.
Sure. _Which_ IP address would you like to change?
Please review this thread, and look for "?". Those are questions.
If you answer them, then perhaps we could make some progress. If you
can't/won't answer them, then I have better ways to waste my time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate your time
When I go on my pc connected to my network
What’s my ip it’s a 172. Ip
When I go to can you see me per that ip it shows ports 80 5000 9000 18004 not open ?
I need to be able to view my security cameras remotely.
My phone app uses my ip to log in remotely and I can’t ?
Until I got the net gear router I was able to ?
Was told by net gear that the 172. Ip is private but it’s there generated ip according to my isp
Net gear did open all ports and I can view home WiFi but again not remotely
Thanks very
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apparently not, or you might stop wasting it, and answer the
questions. For example:
> What's my ip it's a 172. Ip
Still true.
> Was told by net gear that the 172. Ip is private but it's there
You might find this hard to believe, but I STILL HAVE NOT SEEN THAT
IP ADDRESS.
If you're worried about revealing secrets, then the top half of the
address, "a.b" out of "a.b.c.d", would satisfy most of my curiosity.
Or, plug that address into the form at: https://whois.arin.net/ , and
see if it is a public or private address. (Again.)
If the RBK53 (WAN/Internet interface) has a private address, then
port forwarding will not help you with a connection to the outside
world.
Still a mystery.
In my experience, people who talk about ports being "open" or
"closed" often don't understand the problem.
I still know nothing about your (unspecified) "my defender security
system", or why it might need port forwarding for proper operation.
I still know nothing about to what your RBK53 is connected. "a
spectrum modem" is not a useful description of anything.
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
I don't expect that to help you, but I'm tired of fighting you to get
the most basic information about your problem.
