JohannesM's avatar
JohannesM
Follower
Jun 22, 2021
Pioneer as-wl300 wifi Versus a netgear wnce2001 WiFi Adapter
Hi, I would like to no if the WNCE2001 unit will connect up to a Pioneer AV Amp that has a LAN socket to connect to a WiFi or Network router. The router and the AV amp are not in the same room hence I need a adapter. The router is a ASUS RT-AX55. I do have a spare Netgear router NF18ACV Dual Band. So what is a good inexpensive but also simple way to connect the AV amp.
1 Reply
  • plemans's avatar
    It *should* work if you already have that adapter.
    I wouldn't buy it if you don't because its a pretty old device and there's better devices for the same/cheaper price if you're buying something.
    (most wireless extenders have an ethernet port you could use)
