× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Question on 'Use Computer MAC address'
I just signed up fo xfinity service (cable company here in the US).
the connection (cable modem=>ethernet cable=> pc) works just great.
However, when I put netgear router in between cable modem and a pc, I was getting no internet up until I switched to 'Use Computer MAC address'.  The netgear router works like a charm and this is not a hardware router issue or anything like.  This is more how xfinity delivers services...
Could someone explain to me why I must have my PC's mac cloned by the router?
I read couple other posts on this claiming that this is because ISP only allows one MAC per cable line.  But this makes no sense, because when I use a different laptop with different MAC all works just fine.
Message 1 of 8
Accepted Solutions
schumaku
Guru
Re: Question on 'Use Computer MAC address'
The "Use computer MAC" is for those silly ISP which take and keep the previously connected computer MAC address on the cable modem so the Cable Modem does not have to be rebooted after used/tested  with that very same computer [direct connected], and you don't have to call the cable TV operator.
If you don't have a problem, do not enable this feature: Because it will kill your Internet connections because the (again very same silly ISPs) allow just one MAC address - and when changing the MAC address of your router (this is what happens, the computer MAC will be copied to the router WAN/Internet port!) your router will not be able to get a public IP address.
For some ISP, rebooting the cable modem (and wait five minutes till it's provisioned again) and then bring up the router will most likely fix things - and no need for stories or wasting the ISPs support resources.
Message 7 of 8
All Replies
antinode
Guru
> [...] But this makes no sense, because when I use a different laptop
   They could keep a list of valid MAC addresses, and still not know
about your new router.  I know nothing, but it's possible that they'll
accept the first two addresses they see, or all that they see in the
first few minutes after the initial connection, or ...
   The threat is that if a cable-TV type ISP didn't track your MAC
address(es), then some evil-doer could tap into cable, and steal the
service.
   If you set the router's (WAN) MAC address back to its default, and
reconnected it to your (unspecified) "cable modem", and then called
Comcast, and gave them the appropriate MAC address, then I'd guess that
all could be made well.  (At least in this one dimension.)
Message 2 of 8
No, I am not sure that what you said is a complete picture of an issue.  for the same cable modem, for the same ethernet cable I can literally have dozens of dirrent computers that I can plug in interchangeably to that one cable and every time the connection will deliver internet.
I think there are other reasons why MAC address a pc needs to be spoofed by a router...
My hunch it has has to do with the headers on how PC/router send and receive information.
Message 3 of 8
antinode
Guru
> [...] I can literally have dozens of dirrent computers that I can plug
> in interchangeably [...]
   Did you "literally" try "dozens of dirrent computers", or are you
getting your "facts" from the White House press office?
> My hunch [...]
   If I really wanted to know, and I were a Comcast customer, then I'd
try asking Comcast before I started inventing fanciful stories.  But
that's just my own attitude.
      https://www.youtube.com/watch?v=4-ImRMJX68s
Message 4 of 8
I tried on 4 computers.  1 desktop and 3 laptops.  All worked just fine.
I 4 work, then a dozen is expected to work as well and so is 1000 as well.  In statistics, there are these concepts of sample and population...
but you make a good point: I should ask xfinity how MAC addressing works instead of posting here.
Message 5 of 8
antinode
Guru
> [...] I 4 work, then a dozen is expected to work as well and so is
> 1000 as well. [...]
   "expected" by you, perhaps.  What if there's a limit somewhere, of
which you know nothing.  I can hold four eggs in one hand.  Does that
prove that I can hold a dozen eggs, or 1000 eggs?
> [...] In statistics, [...]
   Not all problems involving numbers are statistics problems.
Message 6 of 8
schumaku
Guru
Message 7 of 8
Thanks for an explanation.    What you say makes sense and does provide an answer.
Every time I switch pcs (ie different MAC), I have to re-login into my account.  Initially, I did not think much about it but given what you said I think ISP updates its logs with my new MAC address every time I log in.  thats why bunch of different computers work while router with diff MAC does not.  It all makes sense now.
Thanks so much again, @schumaku !!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 5360 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
