IDpotato2019's avatar
IDpotato2019
R6120 Can this model be bridged
If so can you point me to some instructions?
Thanks.
  • If you mean can you use it as a wireless repeater in a Wireless Distribution System (WDS) system, then, according to the manual, the answer appears to be no.
    You can use the R6120 as a WiFi Access Point, wired back to a router.
    • antinode's avatar
      antinode
      Guru
      > R6120 [...]
         Firmware version?
      > [...] Can this model be bridged
         What, exactly, does "bridged" mean to you?  What is the actual
      problem which you are trying to solve?
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual.  Read.  Look for "bridge".
      (Don't expect to find much.)
         Repeat for a different model: R7000.  In its User Manual, look for
      "Set Up the Router in Bridge Mode".  If that describes what you want,
      then I doubt that an R6120 can do it (unless its firmware is more
      capable than its User Manual suggests).
      > btw, I want to bridge it to a belkin wireless router.
         I wouldn't expect that to matter much, but "a belkin wireless router"
      is not a very detailed description of anything.
  • michaelkenward's avatar
    michaelkenward
