Brian783's avatar
Brian783
R6300v2 slow wifi speeds
My r6300v2 is getting slow wifi speeds. I have tried changing the channels and still no luck.
I am using charter spectrum. Internet from isp modem is 67. When I connect over wifi I get 30. Is the any settings I can change to make this better? I already upgraded to the latest firmware. Did a factory reset. Un plugged it and restarted.
Any ideas? Thank you.
  • Hi Brian783,
    Please try re-flashing the firmware of the router then do a factory reset and check if the issue persists.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Brian783,
    1. What is the firmware version on the router?
    2. Does the issue persist on both bands (2.4GHz and 5GHz)?
    3. Does the issue persist on all your wireless devices?
    4. What is the speed that you're getting when wired to the router?
    Dexter
    Community Team
    • Brian783's avatar
      Brian783
      firmware v1.0.4.8_10.0.77
      issue persist on 2.4ghz. i dont use the 5ghz except for xbox360. nothing else i have will connect to it. so i never tested the 5 ghz.
      issue does persist on all devices.
      wired directly to the netgear router i got 65.95.
      wireless i got 33
      on channel 1 for 2.4 ghz
      thank you
    • Brian783's avatar
      Brian783
      i connected my phone to 5ghz. i got 3mbs download speed.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Brian783,
      Dexter
      Community Team
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi Brian783,
        I would like to follow up and check if you are still experiencing the issue.
        Dexter
        Community Team
