- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Randomly getting Internet disconnected
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there!
I've adquired recently the R6080 Netgear router, is got its lastest firmware 1.0.0.42. Thing is that it will constatly drop connection for no reason. I use mainly my computer which is wired to it, yet randomly the orange light will pop and the connection will drop for a few seconds.
Logs go like:
internet disconnected
internet recconected IP at date
It happens very randomly, can be every few minutes or every hours, it's annoying specially while gaming or hosting a service. and yes I tried connecting directly to my modem and this issue won't happen at all so it's not my ISP. Also tried downgrading firmware and still no luck.
Could be that my router is faulty? Or is there some configuration I could pull of to fix it.
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Xando wrote:I've checked on the documentation and on my modem's configuration and it's already got Bridge mode set and no NAT https://i.imgur.com/UGu66xb.png
I should mention that I've formerly used at least two other routers before with this modem and haven't had this particular issue.
I've seen several different brands of combo devices that didn't properly implement their bridge modde.
What I'd try for troubleshooting?
put the zyzel back in router mode but disable its wireless. Then run the netgear in AP mode. See if the problem still happens. If it does, it wasn't related to that. But if it doesn't, its an issue with how zyzel implements their bridge mode.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Randomly getting Internet disconnected
What modem are you using?
have you factory reset and re-installed?
or tried re-loading the firmware? if the firmware was corrupt, a reset doesn't overwrite it. it just removes settings. so try re-loading the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is a "Zyxel P660ru-t1 v3"
I think I have done factory reset? Is it by keeping pressed the reset button and configuring the router all over right? If so, I did that once.
How do I re-load the firmware? I just attempt to upload it despite being the current version, right? Will give a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reuploaded the firmware but the problem is still present, attached the log so you can see what I mean.
- Mark as New
- Bookmark
- Subscribe
- Permalink
your Zyxel P660ru-t1 also has an integrated router.
https://kb.netgear.com/30186/What-is-Double-NAT
that can cause issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
