× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ReadySHARE USB Printer for macos High Sierra - Installation Is Incomplete
darrenlhr
Follower
Hi,
I am having trouble installing the ReadyShare USB Printer (ReadySHARE USB Printer MAC_V2.36) on macOS High Sierra. Whenever the installation completes and the machines reboots, Netgear USB Control Center is giving the following error message
" Installation is incomplete! Please reinstall again. "
How do i fix this? Or is the software incompatible with High Sierra? Kindly advice.
Thanks,
Darren
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 16
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: ReadySHARE USB Printer for macos High Sierra - Installation Is Incomplete
Hi all,
You can download the new USB Control Center app using the link below.
https://kb.netgear.com/000053245/
Dexter
Community Team
Message 16 of 16
All Replies
RRM855
Apprentice
I have the same problem after upgrading for Sierra to High Sierra (not to say it was not erratic before). I suspect it is the incompatability for the new OSX version. Netgear is slow to make updates for Mac users if at all. I will continue to monitor to see what they do about it.
Message 2 of 16
vc_stargazer
Guide
has anyone contacted netgear about this?
Message 3 of 16
Theslop
Initiate
Just installed the R7800 Smart WiFi router and when trying to download the 'USB Control Centre utility' the website comes up with file not found.
Any ideas?
Message 4 of 16
Kneelb4z0d
same problem here,
removed old app reinstalled new app, says installation incomplete. looks like im gonna have to move the laser printer next to my mac so i can print to it. tbh the app hardly ever worked anyway before i upgraded to high constant restarts to get it to print, i need to find a better solution to the problem.. i might just go with another brand as the QOS is messed up on this router aswell
Message 5 of 16
Pravz
Same problem here.. Looking for a solution.
Message 6 of 16
Hawkeye1027
I was having the same problem, having to restart (router, PC, printer - sometimes all 3 at once) just to get the connected printer to print.  It showed it was in Ready status, but kept getting printer error messages on my PC.  The problem turned out to be my printer USB cable, which is about 15 feet long.  Even though it was less than a year old, once I replaced it with an Anker cable of the same length and the problem went away.  Smiley Very Happy
That was a month ago.  I now have a new issue - the USB Control Center doesn't want to connect with my printer.  I can switch from "Available" status to "Mannually Connected by (PC name)". After 10 minutes it disconnects. Smiley Frustrated  IDK if this was caused by the router firmware update, or the Win-10 update a few days ago, since they were both just a couple of days apart.  I'm leaning toward the Win-10 being the culpret, since I was able to print after updating the router.
Model: R7000|AC1900 Smart WIFI Router
Message 7 of 16
RRM855
Apprentice
I am still waiting for the ReadySHARE USB Printer utility version 2.4 for Mac High Sierra to be released.
Message 8 of 16
bobbycee70
Tutor
Yeah, still waiting here for Mac iOS 10.13 update too 😞 I might just opt to purcahse a standalone print server...
It just seems as though this is planned obsolescence - I'm comfortable and aware that drivers update, etc., but this is just a real pain that I can count on long term use.
Message 9 of 16
chadpatt
Initiate
Instead of using this very poor software, use the built in drivers in OSX.  I can by pass this software and directly print to the IP of the router.  Follow these steps.
System Preferences> Printers & Scanners
Add a printer
Select IP on the top menu
in the Address box put in the ip of the router
select HP Jetdirect - Socket
in the Use Box, select your printer software
and hit add.
On my setup, it works perfectly and super fast.
Message 10 of 16
RRM855
Apprentice
Would that work for non-HP printers? What would happen if you left it at Internet Protocol Printing?
The 2.4 utility does work, it is just that it has to constantly be reconnected upon start-up and if it has been left idle for a while. Do others know a work-around for that problem?
Message 11 of 16
chadpatt
Initiate
Yep, my printer is a Brother Lazer printer.  I had no problem printing to it via this method.
Message 12 of 16
antinode
Guru
   The protocol (using port 9100) was developed by HP, but adopted much
more widely.
      https://hacking-printers.net/wiki/index.php/Port_9100_printing
Message 13 of 16
Kneelb4z0d
Is your printer connected via the USB port on the router? As my HP laser jet is not found when I follow your steps?
Message 14 of 16
DGolden
Thanks Chadpatt!  Your method of adding IP printer worked for me 🙂
Message 15 of 16
DexterJB
NETGEAR Moderator
Hi all,
Dexter
Community Team
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 7531 views
  • 6 kudos
  • 12 in conversation
Announcements
Orbi WiFi 7
