vojtec's avatar
vojtec
Tutor
Apr 16, 2021
Recurring notices to update firmware for WNDR3400V3, But no updates available.
Every day, multiple times during the day I get a notice to update the firmware. After going through the proceedure and selecting "Firmware Update" and "Check" i get a notice "No new firmware version available". What must I do get  messages only when applicable updates are available.
  • What modem is it connected to?
    You're a bit out of date, if you manually update it, you should stop getting the notices.
    • vojtec's avatar
      vojtec
      Tutor
      My current version is V1.0.124_1.0.67. yes I can manually update - but thats not the problem.  Its the constant stream of "update available" notices such that I can't tell when there is an applicable update for my router.
      • plemans's avatar
