× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Trying to Change The Name of the Ethernet Network (Not Connection Name)
mgfarnum
After installing the Netgear R6300 Router I changed the name of the WiFi networks (both 2.4 and 5.0) without issue but the default Network name for the Ethernet Connection is Network 5. I have gone to Network Setting and I can change the Network Connection Name from the Windows user interface from Ethernet to something else but I can't seem to find a way to change Network 5 to something else. Thanks
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Trying to Change The Name of the Ethernet Network (Not Connection Name)
Hi @mgfarnum,
This is not something that you can do through your NETGEAR device since this is how Windows configured their operating system and network naming scheme. You can check this link and see if this is something that you are willing to try.
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @mgfarnum,
Dexter
Community Team
Message 2 of 3
mgfarnum
Thank you. Thios solution worked perfectly.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 31104 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
