atempo
Oct 25, 2019Aspirant
how to access router os?
hi, i'd like to access router os directly.... but there is just configuration web page... i guess..
cuz, there are few ip that i don't want to connect... so, i want to delete them all....
Is there any method that resolve my problem...?
> [...] i'd like to access router os directly.... [...]
Which "router"?
> [...] cuz, there are few ip that i don't want to connect... so, i want
> to delete them all....I don't know what any of that means. Do you?
> [...] Is there any method that resolve my problem...?
I have no idea what your "my problem" is.
> Model: EX6150|AC1200 WiFi Range Extender
That's not a router.
Some Netgear router models (with some firmware versions) can allow
shell access using a Telnet connection. A Web search for terms like:
Netgear Telnet enable
should find some programs which might help. (I use the program which I
modified: http://antinode.info/nte/ ) But I would not bet that such
access will help you to solve whatever your actual problem might be.
Which "router"?
access will help you to solve whatever your actual problem might be.- atempoAspirantSorry, my bad..
I mean this one
'N300 WiFi router '
