Elsaetka's avatar
Elsaetka
D6200 Will not connect after upgrade to fibre (UK)
Hi, I have a fairly new D6200 Router which has worked perfectly on standard (UK) broadband for the past few months. I upgraded to fibre with my provider (Plusnet), and I was called by a BT Openreach engineer yesterday to say he was carrying out the upgrade so I would be off line a short while.
After a long time I still had no internet so called Plusnet support who were brilliant, they said there was no problem with the line and ran through the usual re-starts etc.
Plusnet had supplied me with a new router, however I was reluctant to use it as the Netgear was performing really well, however under the circumstances I had no choice but to connect their router and it connected straight away.
My understanding was the D6200 is just plug and play, however if I am missing something would someone please come back with a straightforward step by step process I need to follow to get the D6200 to connect, replies from those with the info would be appreciated.
Thanks in advance
Paul
  • > Plusnet state for their fibre broadband:............
    > [...] Does your router say VDSL2 Fibre in its product description?
       Clearly, it does not.  If your ISP requires a VDSL modem, then the
    D6200, which does only ADSL, is not suitable.
  • michaelkenward's avatar
    michaelkenward
    The D6200 is a modem/router, not just a router.
    Elsaetka wrote:
    Plusnet had supplied me with a new router, however I was reluctant to use it as the Netgear was performing really well....
    A wise move. The Plusnet box seems to be one of those nasty BT Homehubs in a different colour.
    You don't say what sort of internet you had before Plusnet came along. Was it ADSL?
    Have they now converted you to Infinity? (Or whatever Plusnet call it.) If so, you are now on DSL. The D6200 should handle that just fine.
    But you would do well to reset the D6200 to factory settings. ADSL configuration is very different from DSL.
    There is a manual for the D6200 somewhere at the end of this link:
    >>> D6200 | Product | Support | NETGEAR <<<
    See pages 13 and 146.
    After you do the reset, plug the D6200 into the line instead of the box that Plusnet "gave" you.
    Then you should be able to tale the modem/router through the setup process.
    BT, and probably Plusnet, have a pretty basis login regime. Just use your Plusnet email address with no password.
    If you are lucky, the setup wizard will get the right settings for you.
    After things are working as you want, you can go back in and change the settings on the  D6200 to get back the wifi settings you had before, SSIDs and passwords, for example.
    • Elsaetka's avatar
      Elsaetka
      Thank you for coming back to me Michael, unfortunately i'm still not making much progress.
      No matter which way I connect the DSL it will not connect to the net. I ran the NetGear Genie and self diagnosis states no DSL cable connected, even though it is correctly plugged into the router. Genie also reset the router (so did I with the reset button as advised), again, no luck.
      However, as soon as I plug the cable into the new PlusNet  router, everything works perfectly.
      I tried another router, again another powerful unit made by TP Link and I hit the same problem.
      I'm not an expert so i'm struggling here, however I am thinking I need the actual router settings required by PlusNet, so I can manually enter them into the D6200?
      Very frustrating
      • antinode's avatar
        antinode
        Guru
        > [...] Plusnet had supplied me with a new router, [...]
           Not a very detailed description of anything.
        > [...] I tried another router, again another powerful unit made by TP
        > Link [...]
        > I'm not an expert so i'm struggling here, [...]
           So is any non-psychic reader trying to guess at your equipment
        inventory, or the capabilities of your devices.
        > [...]  I need the actual router settings required by PlusNet, so I can
           That might be a good idea, but, before worrying about such details as
        settings, it might help to know if your new fiber service uses VDSL for
        your connection.  The DSL modem in a D6200 is ADSL-only, and may be
        unable to connect to a VDSL provider.  If the (unspecified) "a new
        router" says that it's making a VDSL connection, then that may explain
        your problem.  If your (unspecified) "another router" also has an
        ADSL-only modem, then it might do no better for the same reason.
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual.  Look for "ADSL" and "VDSL".
        Repeat for another model, like, say, a D7000.
        > [...] ADSL configuration is very different from DSL.
           Nonsense.  ADSL is a type of DSL.  So is VDSL.
              https://en.wikipedia.org/wiki/Digital_subscriber_line
              https://en.wikipedia.org/wiki/VDSL
