× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How can you reduce router wireless signal strength?
kennybee
How can you reduce wireless router signal strength?  If so, what routers allow you to reduce wifi signal strength? How?
Message 1 of 3
Accepted Solutions
TheEther
Guru
Re: How can you reduce router wireless signal strength?
Some routers have a radio transmit power setting.  The R7000 has such as a setting.  Other Netgear models may also have it.
Another option is to load 3rd party firmware, such as DD-WRT, Tomato and others.  They should all have radio power settings.  Not all routers support 3rd party firmware.  Check the respective firmware websites for details about supported models.
Message 2 of 3
All Replies
TheEther
Guru
Message 2 of 3
kennybee
Thank you TheEther Sensei
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 14493 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
