- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
network genie password reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having issues accessing my netgear genie account. I can get into the remote portion of it but not the local. I have tried answering the security questions for a password reset and I know I have one of them correct but I'm not sure about the other one. I'm trying to get access so I can change the password for my router and also the remote portion. I have people not paying rent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: network genie password reset
What's that?
There are several "genies" and several "accounts". So there is no simple answer.
Take us through what you are doing and where it fails.
Do you mean the wifi password?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
Check the section in the manual Specify Basic WiFi Settings.
If you mean that you cannot get into the browser graphical user interface (GUI) for your modem router, then maybe someone changed the password for that. (The default password is on the label ion the thing.) If you have forgotten the new password, then the only solution is to reset the device to get everything back to the factory settings on that label.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Adamlfrd wrote:
I can access the remote portion but with the local, which I am assuming is the access to my router, I don’t know the password anymore.
Anywhere Access, previously called Remote Management, refers to the username and password you set up to get into various things, and not just the controls of the modem/router. The router has its own password, just as it does for the wifi.
It effectively uses the cloud to use Netgear's servers to sneak up on your device from the outside world.
This is just the first step into getting into the devuce's own controls.
If you don't know the password for the router, then you will have to do a factory reset.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
When you have done that, either set up password recovery – check the manual – and/or make a careful note of the password you have set up.
