jlacasci
Oct 03, 2022Initiate
Auto crop for orientation canvas 2
I am interested in purchasing the 16x24 canvas II. I will not use the frame for art but for my own photographs. I intend to upload a playlist of both portrait and landscape images. If I mount the frame on the wall in landscape orientation, can the product display a portrait-oriented image by automatically cropping the sides of the image to fit? I don't want the product not to display portrait-oriented images because the frame is mounted in landscape orientation, and I do not intend to rotate the frame.
I've been told conflicting information by the Concierge live chat.
Thanks,
Joe
There's not a "yes/No" answer.
I have mine set to orientation match so it only displays photos that are in the proper orientation.
You can disable that so photos do fill but you'll have the black bars on it.
but there's also a "fill mode" where photos that don't match the orientation can be displayed. and how you want the edges displayed.
Not sure if that was helpful or not. I attached a photo of what fill mode is on mine.
