dcvgi
Jul 26, 2016Aspirant
AirCard® 340U (Telus) USB Modem
Can I use AirCard 340U (Telus) USB Modem in combination with DGN2200M modem router????
I want use the DGN2200M for ADSL and, if the ADSL fails, i want use a 4G connection with the AirCard 340U.
Is it possible??
Is the AirCard 340U compatible with DGN2200M???
Thanks to all.
- DarrenMSr. NETGEAR Moderator
Hello dcvgi
Here is the list of compatible devices.
http://kb.netgear.com/app/answers/detail/a_id/24196?cid=wmt_netgear_organic
DarrenM
- dcvgiAspirant
I know this.
The problem is that there are no 4G compatible modem in the list!!!!!
There are only 3G compatible device!!!!!
Is for that reason thet i want use AirCard® 340U in combination with DGN220M!!!
