× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Is there an AirCard 431U (Sprint) driver for MacOS Catalina (version 10.15)?
DiVo
Is there an AirCard 431U (Sprint) driver for MacOS Catalina (version 10.15)? Was someone able to make the modem work on Catalina? Netgear, any estimations when the driver for MacOS Catalina would be avaliable?
When I tried driver version 2.5.1 from https://kb.netgear.com/27019/AirCard-341U-Sprint-Downloads-and-Documentation and some older driver versions, they all were rejected by OS as incompatible.
Model: AirCard 341U|AirCard 341U
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: Is there an AirCard 431U (Sprint) driver for MacOS Catalina (version 10.15)?
Hi @DiVo
Welcome to NETGEAR Community!
Please visit this link for Aircard 341U (Sprint) Software updates:
https://www.netgear.com/support/product/341U.aspx#download
Blanca
Community Team
Message 2 of 3
DiVo
Hi Blanca_O,
Thank you for welcoming and your reply. Though, I'm a bit confused with your reply. Could you please elaborate a bit on what I should find on https://www.netgear.com/support/product/341U.aspx#download page? The way that page is shown to me, I only see there links to downloads of the drivers version 2.5.1 (which I mentioned does not work on MacOS Catalina) and version 2.3.0 (which I actually referred to as "some older driver version" without mentioning the exact version number). So, I have tried both and they don't work on Catalina. Did you referr to something else that should help me to get AirCard 431U working on MacOS Catalina and that I'm missing?
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 952 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
