bigbillsdd's avatar
bigbillsdd
LM1200 IMEI on CricketWireless says its not compatible. (Its ATT)
Model = LM1200   Not available in the Model Picklist when creating this thread.
I just purchase one of these to use with Cricketwireless on their 100GB for $50 plan.   They says its not compatable due to the 3G modem.   Why would a new product have a 3g modem in 2021.  Most vendors have shut off or will shut off 3g within the next 60 days.   Do you have a hotspot without a 3G modem that can be used on Cricketwireless?  -Bill
  • plemans's avatar
    It has to be a cricket approved device. You'd have to check with cricket to see what they support.
    • bigbillsdd's avatar
      bigbillsdd
      They have no such list.  Only their #2 hotspot which is an even slower device than the LM1200.  And their hotspots specs says its also 3g.  It makes me wonder why they car what hotspot is used.  The plan I am looking at is 100GB per month, then its useless till the new month.  I looked at visible, no coverage in Mexico and Canada.  Which Cricket does a really decent job in those countries.  -Bill
      • plemans's avatar
        I wish it was something netgear controlled but its all cricket controlled as to what devices they approve
